OneLever
- June 26, 2010
- 97 Mt. 5.0L AWD
the light above my rear seat (so interior light #2?) is burned out. Any possibility this blown light is preventing the others from being triggered on?
No. My second row interior light has been blown out for a long time and it does not affect the other lights.
OK...get a meter.... and check to see why the relay isn't working.
Get a multimeter and remove the Interior lamp relay shown in Picture 6 of Post #4 above. On the underside of the relay each pin should be labeled with a number. From this you can deduce what the numbers for the pin receptacles are. The Battery saver relay needs to be activated for the following test. It can be activated by simply placing the ignition in RUN. It will remain activated by the GEM after the ignition is placed in OFF for around 30 minutes if the doors are not locked and shut if I recall correctly.
With the Battery saver relay activated check the voltage across Interior lamp relay Pin 3 & Pin 5. It should read battery voltage of around 12.3 V. Shut all of the doors, the rear hatch, and the rear hatch glass. The Door Ajar lamp on the dash should be off and there should be no chime.
Open each door, the rear hatch, and the rear hatch glass by itself one at a time. The Door Ajar lamp on the dash should light up for each one. Check the voltage each time across Interior lamp relay Pin 1 & Pin 2. It should read battery voltage of around 12.3 V only when a door has been opened. It should drop to 0 V when the door is shut.
Ps. anyone know where to find a wiring schematic online?...Any arguments with a Haynes? or is there a better one?
I highly recommend getting a service (shop) manual. Haynes and Chilton are good for fluid capacity specifications and that is about it. The original paper service manual is a two volume set which you can get off ebay. I also got the Electrical and Vacuum Troubleshooting Manual (wiring manual) with mine as well. Here is a general link of what you are looking for, and a specific link to an EVTM. I believe I paid about $60 for both volumes of the service manual and two copies of the EVTM as a set. These hard copies are worth their weight in gold.
