OneLever
- June 26, 2010
- 97 Mt. 5.0L AWD
Check for continuity from Battery saver relay Pin 3 to both receptacles of Interior fuse #27. You may have gotten Pin 1 and Pin 2 of the fuse confused.
You said you could turn on the interior lights manually with the dimmer switch by pushing it all the way up right? If you look at the diagram above you'll see power flows through the Battery saver relay, Interior fuse #27, and finally the Dimmer switch. Meaning there must be continuity.
I suspect your problem is with the wire from Interior fuse #27 to the Interior lamp relay (705 LG/O), the Interior lamp relay receptacles, the Interior lamp relay itself, or the wire from the Interior lamp relay Pin 2 to GEM (1008 LG/O).
Edit:
It can be difficult to get multimeter test leads in contact with blade receptacles. I suggest ripping the blades out of a spare fuse you have laying around with pliers. Insert those blades into the receptacles to be tested and attach your test leads to them. You can get test leads with alligator clip ends which makes this easier.
Edit:
