what about an 06 f-150 my buddy has one and he wants to find out what the code is
I have an '02 XLT and the door code just stopped working. The lights (on the pad) come on but the code will not unlock the door(s). I can still push the bottom buttons to lock it, just won't unlock. Anyone have this problem and how do I fix it??
Well, guys, this happened to me too. I replaced a few engine sensors and unplugged the battery to clear the codes. When I plugged the battery back in, the keypad quite working. I found the factory code with my manual, it didn't work. I pulled the trim panel to find the code on the security module, it was the same code, and it didn't work.
So to re-hash, i plugged the battery in, and it killed my code. the pad will lock the doors, and light up, but it won't unlock anything
Please post if you have solved this problem before.
BigRondo, tried it the way the Owner's Man says, but after reading it carefully this method is for adding a second code to the KES. Is there a way to reprogram the original code or do I need a new control box?
I found the numbers and tried all the above and other internet post on how to change, erase old personal numbers and still does nothing. The only thing I can do is lock the doors with holding the bottom two buttons......
Fellas this sounds exactly what happened to mine. Hopefully someone posts a fix.
It would still light up as long as the 12V wire & the ground wire are still intact.
Try pressing the 7/8 and 9/0 buttons at the same time. This should lock all doors:
Dead Link Removed
Double check to make sure you have the correct factory code. If you're sure you have the correct factory code and you still can't get it to work, then check again for broken wires. Make sure the connector for the keypad is fully seated.
I'll see if I can scan the keypad wiring diagram for you when I get home this evening.
I'll take that diagram if you're still offering! I have no power going to the keypad.
You can add a personal code, but the factory code is there forever. Doesn't matter what goes down. The factory code is always there.
I'm gonna go ahead and scan the wiring diagram and any troubleshooting info from my shop manuals.
Hope you can get it going!
There was only one 5-digit number on the front of the security control box that was behind the middle passenger seat. I tried and don't get why it won't work. I'll look forward to the info, thanks man!
lots of locations for explorer security box how about a location for sport trac codes??
