- June 16, 2003
- Humboldt, KS
- 2000 Mounty
I just thought I would start this thread and let you guys help make it.
I for one have cooling issues on a 2000 Mountaineer V8. Using a scanguage shows coolant temps approaching 230 degrees with the AC turned on max during a day it is needed. Even on a cooler day where temp is "tolerable" , Ambient 80 degrees or so, even with a 193 thermostat coolant temp runs 197-198 at 70mph without AC turned on.
I know a lot has to do with the Winch, bumper and skid plate, however , even with these temperatures, my stock cluster gauge stays right in the middle. everything's good it says.
After doing a little posting in my registry and good answers provided I dug deeper.
96-97 V8 explorers and mountaineers come with a 2 row radiator, and 16 psi pressure cap
98 V8 explorers and mountaineers have a 2 row radiator and 13psi pressure cap.
99-01 explorers have single row radiators and 16 PSi radiator cap.
Here is an LMC truck link ( you can verify at rockauto) for radiator cap. I used this because it is more concise.
http://www.lmctruck.com/icatalog/fex/full.aspx?Page=57
I will use autozone links for comparison of radiators.
97 radiator . Specs say 2 rows, 2.25" depth of core, 19.45 lbs and, 171.99 in this area
http://www.autozone.com/cooling-hea...9189_0_0?fromString=search&make=&model=&year=
98-01 radiator. clearly less "robust" at 1" depth of core , 16.45 lbs and more robust in price, 193.99 in my area.
http://www.autozone.com/cooling-hea...premium-radiator/352649_0_0?&searchText=b2308
Ok what gives?I'd like to think I know my way around these things but this is relatively new to me. Seems there may be more differences than we know about.
I have a suspicion, hear me out.
98 up also went to external egr-
96-97 have internal egr which passes hot gas directly into the intake manifold.
I think the latter intake ran cooler resulting in lower fuel efficiency, or, they were trying to increase fuel efficiency in the later models by warming the upper intake.
98-up upper plennums have 2 coolant lines, which circulate heated coolant via the heater core crossover tube through the upper intake manifold. I presume they increased the coolant temps as a further "enhancement" to these models.
Since I have a good baseline of temperatures on our brick of a truck, I will update this information when I swap to the early 97 2 row radiator.
Any input is eagerly accepted.
