410Fortune said:
Um the 3.57 shim is listed on the website but is only 3.75 degrees when used in a 2wd truck, the same shim installed in your beams will be 2.75. that is why your 2.5 shim box also says 3.5 (or should)
Moog makes a 2.75 degree shim for 4x4, Napa, or carquest.
I have to go over this all the time
I hope you are running a 2" drop pitman arm and also extended brake lines with this setup. IN the pictures it looks like extended brake lines, but with TAPE over the ends???? Homemade extended lines = DONT DRIVE IT LIKE THAT!!
I still believe you will punch a hole in your differential pretty soon if you dont do something about the location of that drop bracket (hard to tell from pics)
Edit: the tape your seeing is actually a spider web.. lol
Heh the brake lines are braided that I had made special. 6 or so inches longer than normal (i forgot exact). We had problems getting the clips back onto the frame for the lines, but they are exactly going anywhere since it goes thru the frame. I will look at that dropdown bracket vs my axil differential, I didnt think about that.
The tires dont hit anything in the front, but if i MAX (all the way, as far as i can steer) my steering they hit the radius arms:
Edit: ^^ Thats a really bad angle for the picture...
I guess I need to look for diffrent radius arms or get diffrent rims at some point. Driving down the road doesnt do that, thoes rub marks are from me testing the steering out in my yard, by max, I mean whining gearbox max. Its still a problem tho, dont need to rip off my radius arms on a trail...
Also, I though I read somewhere you could get special ball joints to go with the camber/caster adjustment brackets, that might help some?
Chew_12: The "diffrent" steering shaft works fine it seems. It steers really good. I hold the steering wheel streight and it drives streight.. Just my right side tire camber pulls the vehicle to the right when I let the steering wheel go.. so its not the shaft messing anything up. It may be better than the "origional" because it only has one rubber bushing and a metal knuckle, instead of two rubber bushing (that cant be replaced!). I had bought replacements from advanced auto.... and they were HUGE compaired to the old ones... aka wrong ones, and its listed in there computer as the right ones. Took it back and went junkyard hopping and found that one, totally diffrent, in the same year explorer. Imagine that.
EDIT: Ohh I didnt mean bronco 2... there was no offical packaging lol, and the person who had it (in a french fry box...
) said it was for a full sized bronco. I was able to look up some parts numbers, like the pitman arm, works for an explorer. The radius arm brackets.. fit my frame, had to drill one hole, need to drill about 2 more on the side. Front spring is quite big, but fit in. Angles of steering and axles are not that bad, but not perfict. Its work in progress.
