Ranger to Explorer Front end swap project | Page 3 | Ford Explorer Forums - Serious Explorations
Ive been watning to do the explorer swap on my ranger even before i started building my ranger a few years ago, im not sure why i never did it but this week I covinced myself that if i want it done i jsut got to do it.. so i fiqured why not make a thread on the swap cause im sure some people would be interested in seeing it done. Keep in mind the truck has probably only been painted this way for less that four months now:eek:
Started with a a realtively stock ranger front end, diamond corners and headlights and a billet grill, only bolt on mods but nothing really too labor intensive
Yesterday went to the junkyard and started getting parts i would need to do this swap, since that would be the cheapest way to get the parts and also give me a oem apperence over buying the not so perfect :thumbdwn: aftermarket parts
picked up a passenger fender form a 99 4 door and a driver fender from 00 sport for $75 for the pair. Both had pretty good damage but it wasnt important becasue the very front of the fenders were stragiht and that would be all i was using anyway
The hardest thing to find was a non dammaged header panel from a 2nd gen explorer. i found many 1st gen front ends and even a couple mountaineer front ends in both styles but only came by one undamgaged header panel from a 01 4 door and it still had a set of good condition headlights so i bought those too. The header panel and headlights came to be $78 i had the grill in my basement that i bought along a time ago when i first wanted to do this swap i think that was $5 at a swap meet
that would be enough for now to do the hard part of the swap and get everything lined up right and looking good.
So today i started the actual swap first thing was diasembling the ranger, removing the header panel, lights, and bumper
now that everything was stripped i cut off just the very front of the ranger fenders where the header panel mounts, and the very front of the explorer fender about 2 inches or so back into the fender. making sure not to take to much out of the fender rangers fender or not leave enough on the explorer fenders. i left the explorer fenders alone for the most part and kept trimming back the ranger fenders until the tips of the explorer fenders met with the very tip of the ranger fender and the lower line of the fenders where they meet the bumper are even..mkaing sure the whole time not to cut our more of the ranger fender then i had explorer fender to fill the hole
trimmed ranger fender with explorer fender overlaped over it to position properly before final cutting could be done. i temporarily held the pieces on wiht a clamp and a screw up top which you can make out in the one pic...the hole form the screw will jsut be welded up in the explorer fender but will be cut out of the ranger fender inthe next step
one of our dogs was a lil to interested in the project:confused:
with the fender peices clamped and screwed together i could maunt to the header panel temporarily to check for fit and it bolted right up and aligned fine, with the lower front fender bolts out to allow some play in the front of the fender
everything fit with the header panel well so i closed the hood and ran into the first problem i had:mad:. the hood fit fine as far as bottom of hood to top of header gap, but the curve on the ranger hood is much flatter then the curve of the explorer header panel. sorry i was busy trying to fiqure out what to do and forgot to take pics:banghead:. but then i looked over at my 97 explorer and fiqured id take some measurements....turns out the ranger and explorer hoods are the same width and the same length at the fenders so they fit the same hole. so i took the hood off my explorer and sat it on the ranger and it fit fine and lined up perfect with the grille curve. the only problem was that the hinge bolts are in deffernt places but i will address that later when i get a used explorer hood since my daily needs a hood and i cant use that one:D
only other problem i ran into is that the mounting brackets for the header panel on the core support are simmilar but not exactly the same as the ranger ones so i will either modify mine to work or get explorer brackets and modify them to mount to the core support
with that said i removed the fenders formt he truck and got ready for the next step of mating the explorer fenders seamlessly to the ranger fenders.
i left the pieces i cut form the explorer fenders on the ranger fenders and basically grabbed a sharpie and traced those onto the ranger fenders and then cut out the excess ranger fender..ther wasnt much to it....all the contours form both fenders match up pretty well and should be a breeze to body work
i ground everything down and got ready to weld and had no welding gas so you all will have to wait a few days for the rest...
both fenders cut ready to weld
dont be afraid to ask any ?? you may have i know this post lacks in some areas but it should give a good idea about this process and ill have more pics and progress in a few days when i can get back to it
that is a badass hood but being body dropped im really big on the whole "keep your motor under a stock hood with a body drop" thing so i wanted to kinda follow those lines by keeping a stock expo hood too....but that is really a bad ass hood and would def schange up the look of the front end
we were having a club get together tonight and i wanted to bring my truck out so i spent the day fitting the hood and making a bumper work for it.... i didnt snap any pics of the modifications that had to be done to done to make the hood function and the bumper fit but i will tommorow...i was more interested in getting it together then snapping pics:D
but tommorow ill take some pics of the odds and ends involved and give you all a better idea what was involved to make the hood and bumper work...it was close to "bolt on", but also took a lil adjusting here and there..more on that later-lol
But i did snap some pics of the finished product so far with the hood in primer and the ranger bumper on this week hopefully paint the hood and keep looking for a bumper.....
that's proper rude! I love it... can't wait to see it finished... wish we had more stuff like that over here!
Si
that the first time i take anything i own being called "proper rude" as a total compliment..thanks
havent got alot done lately since ive been busy with other things but here a pic of how i had to raise the stock latch mount to accept the explorer hood and still line up at the fender as best it could..its been dressed up acleaned up since this pic:thumbsup:
and in case monmix is still paying attention..the body work is stragiht.....-lol
hey, do you still have the clear corners and headlights you took off? i'm interested in buying them....btw, great job on your project and pics....
nice :D
Body work looks great
Are you going to the Ford National up at Carlisle ?
A bunch of us from here go up every year.
Great job man. So any pics with the finished hood?
Oh yeah, nice neighborhood. Anyone else notice an Explorer in almost every street shot?
sorry guys i ain't been on here much lately been trying to finish up my buddys truck..but thanx for all the compliments guys...tbars4 ill send ya a pm.....and normally i only hit up the truckin nationals in carlisle casue i love that show...but i believe this year im goin to the spring..the truckin nationals for sure..and i will most likely go to the ford one because well its a ranger-lol and i work wiht a bunch of ford guys so i think were all goin up...........and for the explorers in all the pics the blue one obvioulsy mine..and the white one is an 00 xlt that i sold to my parents a while back when they wanted an suv and i just took my dads ranger till i recently bought my expo.
ohh and more importantly pertaining to this thread.....the front end is all painted i just have to stripe the hood and i have a line on a 99-01 xlt bumper so i should have that soon..but i will get pics when the sun comes out and the nice real april weather comes back :mad:
goodpoint.....and well taken-lol but ive been so busy trying to get my buddies truck to a point anywhere near mine that i can afford to put mine on the back burner for a while....and even more true because im also in the process of doing the interior and im saving the drivers seat till last so i cant drive it till im %100 done-lol but its very close to being done hopefully within a month ill have finished pics.............
but the hood paint pics will be take tommorow and posted asap...thanks guyz
Can't wait to see the finished pics, great job on that man!
Cant wait to see this at the Ford Nationals :D !
Looks great!
I still find it odd that you took two fenders and made one. Is that common? I am no body person by far, but that would be something that I would think of doing to make things easy, instead of hammering, pounding, filling, moulding, the front of the fender to match.
yeah i though it was way easier to section the fenders together to make one then to just straight modify my fenders to work with the expo stuff.....and im still working on pics of the hood i had it all nice a clean but no camera at work...and then its just been rainy and bad the last few days-lol
damn your quick and no not really..but that prolly cause im still not trying very hard -lol
but i do have some pics now of the finished hood...i just had to wait long enough and i didn't have to take them myself-lol
that turned out sharp...i took those clear lights and put them on and thanks again...well that was the beginning of what started out to be just the lights and last weekend became a paint project.... but it don't compare to yours...heres my link when you get some time....
http://www.explorerforum.com/forums/showthread.php?t=186873
Looks freakin sweet !!!!!
What show is that ?
PM me if any other area shows come up.
I want to make it out to a few this year.
