fast_dave
- June 6, 2005
- East Bay - Nor Cal / PRK
- '98 Spt 4.0 OHV 5 spd 4x4
Grant / @97Sandbox
Just sayin'
From memory - my 98 2 Door Sport AWD w/ a 5 Speed Manual Trans had a SPECIFIC rack for it - different from any of the other 2nd Gen Explorers.
Back in 2008, when Factory Re-Built parts were still available, I had a local mechanic replace the rack due to a slight leak from the bellows.
Through a series of aftermarket replacement rack & pinion part mishaps/screw ups (tried to save money and that didn't work out), we learned from the local FORD Parts Department that my specific year/set-up called for a QUICK STEERING RATIO rack. specifically for a 2 Door AWD w/ a 5 Speed Manual Trans.
It took about a week as it had to be shipped from Detroit, and when the FORD Factory Re-Built rack showed up to the shop, it came in a FORD box, the rack had a FORD rebuilt hologram sticker on it, and also a stickler that specified what the parts counter guy told us, which is that it was a QUICK RATIO rack and it listed the Ratio.
I just looked through my electronic records, and the FORD Part Number for the Rack that we settled on is: F87Z3504KCRM
Link: 1998-2003 Ford Gear Assembly F87Z-3504-KCRM | TascaParts.com
One thing I will say - whatever the ratio, I never had problems doing u-turns or cutting into parking spaces. I swear that rack was as quick as any sports car rack.
Also - be aware that over tine you can dial the slop out of the factory rack with careful turning of the big outer nut and the inner nut (scribe witness marks on BOTH) , located on the front/outside of the rack, driver's side.
Link to How to Adjust Rack & Pinion Lash: Good quality replacement steering rack?
Happy New Year & Good Luck
Just sayin'
