2002 work report
Alrighty folks. I have a 2002 Explorer Sport with the 2-3 flare problem, Yes, a 2002!
So, read the thread etc. In digging into the valve body, the VB already had the Ford TSB kit modifications, and the bonded sep plate had no damage. So, by 2002, Ford had made the VB changes.
Since I had the parts already, I put them in.
I ALSO replaced the EPC solenoid, which I wager was the source of MY problem.
So, I think that if you have a 2002 with the 2-3 flare, it's probably the EPC, and not the VB. BUT, I spent another $40 or so for the sep plate and the FORD TCB kit, so it was not too bad for the extra precautions. The Ford kit though, was not necessary since the 2002 VB had those items already in it (and the other items were removed as recommended by the Ford kit instructions).
Best advice from the thread: make a cardboard template using the new bonded separator plate. Draw the outline and the bolt holes on the cardboard. Use a utility knife to poke holes into the cardboard. When you remove a bolt, poke it into the cardboard. So simple, and SO EASY!!!!!
So, all in the all, WHAT A GREAT PLACE FOR INFO!!!!
