Hello I'm about to purchase a set of Bridgestone Duelers AT Revo and I was wondering if I would be able to fit 245/70/15 on my truck with out any rubbing issuse or anything. I have aftermarket rims that have a offset of negative 30mm and 15x8 they already stick out alittle bit. With the wider looking rims and the wider tire would i have any fender rubbing or clearance problems Thank you
EDIT
I have new information, I decieded on the 265/70/15 or the 31/10.5/15, The 265 are 29.6 inches in diamater so there about an inch smaller but would I be able to fit the 31 with any rubbing problems with stock height or would the other size fit no problem. I have the running boards if that makes a difference. Thank you
EDIT
