I got tired of using batteries and running out of power points so I installed this AC Outlet in the back of my truck. In the panel, there is a 600Watt inverter and I cut the end off an extension cord, ran it to the connectors on the outlet and installed the outlet. I have a switch up front to turn on power to the fuse block and a seperate one for each accessory, such as the outlet.
