2002GreyHD150
- March 30, 2003
- DFW, Texas
- 2004 Mountaineer 4.6L AWD
hey all... well the 5 month adventure of swapping the engine in my wife's Monty ends this weekend, if it kills me.
I have a no-crank/no-start situation. I have no ignition wire voltage during crank at the starter.
I noticed I have a single, black wire popping out of the main engine harness. It is directly above the #4 spark plug coil on the passenger side. It has a 90* angles female "push on" type connector. I am guessing it is a ground for the PCM, possibly attaching to the top if one of the cam cover hold down studs?
If anyone could snap a quick clear pic of the area around the #4 coil pack, the back of the throttle body and firewall area, I would greatly appreciate it.
I had to transfer all the top end of the Monty to the new donor engine (it was an '03) so I don't have the other engine to use as a reference.
Thanks!
Rob
Thanks!
Rob
