junkYARDbuilt
- May 25, 2009
- Lawrence, MA
- '94 XLT
A few weeks ago I replaced the rear axle seals in the driveway, was pretty straight forward, and now with winter around the corner and a day off from work I want to replace the front axle u-joints. I fond a very informitive sticky post on the whole process, however it only seems to deal only with the two outer u-joints drives and passengers. On the passengers side there is a second inner ujoint which I would like to replace along with the axle seal on that side. Although the drivers front axle slides out of the diff. It doesn't appear as though the passengers side will be so easy. Being that there is no diff. cover on the front axle, will I need to remove the front diff. to remove the entire right front axle assembly to in turn replace both right ujoints and the right front axle seal? Any input would be greatly appreciated, and pictures are always awsome.
