A 30"+ tire on a lowered 2nd gen Explorer is going to rub the plastic inner fenders barely at the center. The diameter and the truck lowered makes that a rub point to watch for. My 265/60/18's did that the most, that's a 30.5" tire.
You cannot lower these trucks a lot really in front due to the alignment problem, and worsening ride quality. I had great success lowering my 98 Mountaineer, but my other three 2nd gen's would not let me lower them very much at all. The Camber gets bad as the truck gets more than about an inch lowered, it varies with every truck. My Mercury could go about 3" down I think with no huge alignment issue, I played with the height for a couple of days before choosing where I liked it and left it, a little over 2" I think.
I measured my trucks from the LCA front bolt center, to the ground. My Mercury is about 2" lower than my other three trucks, each of them at the alignment shop they told me the camber was bad at lower heights. I typically went there each time with the height where I wanted it. hey would tell me how bad the camber was, and we'd settle on a height above that where they said the tires would live. Note I like hard driving, cornering, so a little negative camber is good for me, and my alignment shops knows this. So other people could have to have less camber than me, because they'd wear out the inner edges fast. I even that out by wearing out the outer edge in driving style.
I used the proper camber washer kits with bolts in all of my trucks, for some reason my Mercury was great and the others aren't. My black 98 Limited will be my keeper, so I will have to figure out how to make that go down more.
That being said, the tire width will be limited slightly by how far the truck is lowered, but the wheel offset the most, and what kind of fender flare you have. I'm going to add the optional front flares that are the slimmest, came on many base models, and is about 1.5" wide. The 17x9" wheels I will use are 16mm offset, and with no spacer they will set the tire out of the fender just a bit, about an inch. The limit on the inside is the upper BJ, you have to keep the tire away from those by a good amount, say 1/2" depending on the wheel diameter and tire series. Shorter wheels and taller tires need more clearance for the tires to deflect.
This is the only picture I find handy to show the first tires I put on my Mercury. These are 255/60/17's, with a 1/4" spacer(30mm offset 17x8" wheels(which makes them about 24mm offset(1/4" is 6.35mm))). I had the truck lowered then with the Explorer Express kit, 2 38" rear lowering blocks and front bump stops from a Limited. I lowered it slightly more when I wore those tires out, but it's still very close to that. If you go much lower or bigger with tires etc, you get closer to rubbing. I had none with those first tires, but went to a 265/60/18 next, and worked my way down from there. Now it has 255/55/18's which are 29" tall like the stock 15's and the 17's were.
I would suggest the size range near a 275/55/18 as a limit(that's a 30" tire) with less lowering than with a 29" tire. I was hunting a wheel that was either 17x9" or 18x9", and found two of the 17's first. I was after a particular wheel, so there are lots to choose from, the offset is the big key when you push the tire sizes and lowering.
