RinTX
- March 7, 2005
- Texas
- 92 XLT
We recently purchased a 92 XLT 2WD in pretty good condition, but with a few issues. The first was the driver's power window, now fixed. The others that I'm now dealing with are seemingly common ones, but a couple of questions remain after having search this and other resources.
The problems (NOTE - I added other search terms in () to make it easier for others to find, including "guage" because that's how some seem to spell it ):
1. The fuel gauge (gas guage) seems totally non-responsive - it doesn't slowly fall as it might with a cracked float, it apparently isn't working at all. I understand the idea of checking ohms, but what's the best way to check? Is it removing the left rear tire and accessing the connector at the tank/pump, or ??? Any tips/tricks or specifics to check?
2. The tach (tachometer rpm) is doing the "jump to 3000" thing when the key moved to the on position - key on, engine off, prior to starting - and then remaining in the 3000-4000 once started, regardless of RPMs. I removed the tach, cleaned the pins and motor mounting screws, nuts, and pads, and reinstalled. Didn't fix it. I've found vague references to "a thing under the battery," etc., but nothing concrete. Any suggested tests, fixes, tips/tricks, anything? I can get a replacement at a wrecking yard, but I'd like to isolate it to the tach itself before I do this.
Thanks in advance for any ad all help.
