Do you think between you or offtrac you could squeeze 36s on there or you doubt it? Since you both have 35s, i was just wondering how much more room you have. Either way cant wait to see the ST @ truck nats.
I would say no, but that's also what I was told when I said I was determined to get 35s under there. There's definitely some more room inside the wheel wells but would require more trimming, probably more than I'd want to do to preserve some protection for the engine bay. Just a guess, though. The stock bumpstops have me about an inch from the plastic. My tires at less than half tread, though, so keep that in mind.
On hard downhill turns at full lock, the tires keep grabbing the stock gap guard and ripping it away. So, I have found more necessary trimming or may just need pinned back better. With 36s, you'd probably lose that whole piece and you'd need to find another way to keep the engine bay clean.
There's definitely room in the rear for 36s. A SOA would very easily fit 37s.
I'd be inclined to say no, but for the same reason everyone told me I couldn't do 35s without cutting up the trim like JohnRock and TxPlates did. Side note, I'm getting closer and closer to cutting the trim off (whole 'nother topic
). Same reason everyone told you not to go with 14.5" tires. When something hasn't been proven, most lean toward the side of skeptical. I am skeptical, but wouldn't be surprised if it was possible.
For 2wd guys, I'd guess that a body lift, 3" TT and AAL would give enough room for 36s. Guessing, though.
