01 Explorer cranking but not starting | Ford Explorer Forums
lawman
Canal Winchester, Ohio
2001 Ford Explorer
i just replaced the spark plugs and the wires but when I went to start it it cranks but doesn't start. I think it might be the vacuum hoses needing replaced.....
the engine is a V6 sohc
Help Please!!!!!
Did it start before you did that work?
DId you start the vehicle before and did it work
Yes I did kevinspann it did work but then went to my problem now
check plug wires 5 & 6
Make sure that you didn't misconnect coil 5 terminal to cylinder 6 and coil 6 terminal to cylinder 5. The coil pack is marked with cylinder numbers. Terminals 5 and 6 are not sequential on the pack.
Cylinders:
Rear
3 6
2 5
1 4
Front
