01 expo 5.0 83 bronco c6 | Ford Explorer Forums
Micah J
AZ
94 Expo
Whats up guys. I frequent the first gen forum often, done a lot of expo work but never with a 302.
I'm trying to put a c6 behind my 01 5.0. Getting a lot of conflicting info on if it will work. Some are saying the motor changed 98+ and the older trans wont bolt up. Any info would be awesome. Ive searched for hours.
5.0 (302) is a 5.0 (302) from 1969 -2001 same bellhousing
A c6 will bolt up as long as it came from a SBF
You will need a tune to remove the trans functions from the stock explorer 5.0 computer, or the truck will not run correctly as it is expecting many inputs from the auto trans.
Awesome, thanks for the info. Tune is easy enough.
May I ask why?
Yeah going c6 over the 4r70w
Building a trail rig. Early 80's ranger cab, expo 5.0, factory d44 chassis 4x4
Ahhhhhh I understand now. I'm thinking your trying to put a c6 in an 01 explorer .
Just using the expo electronics
i believe the earlier post is correct the engine stayed the same but mid 90s they did change the way the engine ran but not the engine itself. more electronics and a different firing order or some such thing. think it was something like that i cant remember exactly was a long time but prior to 95 i was a pure ford guy 1979 f150, 1986 f250, 94 f150. after 95 im at a bit of a loss.
Thanks for the info guys, any and all is much appreciated! After more thinking, plan is to use the 5.0 from a 95 F1 and it's harness/computer. Still planning on the c6 and manual t case.
