N2FORD
- January 20, 2002
- Kingston,TN
- 2001 Sport Trac 4wd
01 ST Idleing to high any thoughts?UPDATE
My 01 ST just starting idleing to high the other day after the ride home from work. On that ride home my A/C blew warm air for maybe a minute tops then went back working good. Now it wants to idle at 1500-1800 rpms after driving it on the highway, eventually it seems to drop on down closer to 1000 rpms. Just hoping for a direction to look or someone else that has had this problem. I have not found this specific problem using the search feature.
***Wanted to pass along that it is fixed. It was the failsafe style thermostat ($53.00 retail) that failed. It was causing the truck to go into limp mode, cutting the A/C off and idleing higher to get better air and coolant flow. Hope this helps***
