FrdExp
- January 14, 2006
- Charlotte, NC
Greetings,
Looking for some tips about removing the front brake calipers on my 02 Exp. Got concerns over the ABS fitting bolt.
I have the Haynes manual it. On page 9-7; Removal, para. #2, it mentions removing the inlet fitting bolt and fluid may drain. Anyone know if this is a serious bleeder or just a trickle? What can I expect?
This will be my first crack at doing a brake job with this type of set up. I'm especially concerned about the fluid leaking out of the caliper. Any tips will be greatly appreciated. Anything I need to be concerned about with the rear? Will be replacing pads and discs, front and rear. Thanks in advance.
Keith
Keith
