02 Explorer Ignition Part? | Ford Explorer Forums
pikeviewflury
Apex, NC
'02 XLT
Hey All!
First off, my trusty 02 explorer almost has 200K on it!
My key stuck in the ignition switch and could not get it out, neither could a lock smith. Drilled out the tumbler teeth enough to extract the key, then drilled out the release pin and that didn't work.
I attempted to carefully drill out the lock tumbler with progressive bit sizes and the last one caught and ripped the tumbler out of the housing.
I need to replace "the part" what links the lock tumbler to the ignition switch.
Does anyone know that "This Part" is called? and if so if I can buy one anywhere?
I thought I'd give you all a shout to see if I can buy this "part" or If I have to buy a whole new column at a salvage yard just to extract this "part".
Thanks
Can you take a pic? Use Photobucket to post.
