'02 Explorer Sport hard starting, running at idle. | Ford Explorer Forums
Rob Mastropietro
Danbury, CT
2002 Explorer Sport
This problem began today- engine was warm, and began to idle very roughly, and misfiring. CEL is on and flashing. There is a very rich smell of fuel mixture. The problem has not corrected itself by shutting the engine down and restarting.
A few weeks ago experienced this problem with a cold engine, but it smoothed itself out quickly with no further problems untill a few days ago when I noticed a very rough idle and rich fuel smell, along with excessive exhaust smoke. I shut the engine down and restarted, everything was fine.
I have not connected it to any diagnostics equip. but I am told by a friend that Auto Zone will do that for you at little or no cost.
Any thoughts on a possible solution?
welcome
2002 Ford Explorer Sport
Codes P0303, 0304 and 0306 show that Cylinders 3, 4, and 6 are misfiring, so I am assuming it's an ignition issue.
Car has 65k on it and well maintained.
I got codes read this morning- P0303, 4 and 6 indicating misfiring in the 3rd, 4th and 6th cylinders- so I assume I have an ignition problem
Rob, If that's a 2002 2-door, then you've got a Gen 2 platform and will likely get better help posting in the 1995-2001 forum. Could be an intake manifold gasket failure. Good luck.
I'm sorry about that- will be sure to get onto the correct forum in the future. Thx.
