'02 explorer with bad starter? | Ford Explorer Forums
dsd1983
2002 Ford Explorer
title says it all...
i got a 2002 ford explorer 4.0 xls with 4x4
starter is bad i am pretty sure, had a bad battery in it, told wife not to drive it, i guess i should have hid the keys, got a call one day and she was at work and said the car wouldnt start. starter was clicking and now makes no clicking at all, i am thinking starter is bad, put a new battery in it and when i turn the key on the door buzzer starts dinging, radio comes on, etc but when do to start, one click and thats all, i am thinking it is the starter...
so if i am right, what does it take to get this starter off? i looked under the car and it seems it is quite in there and things would have to be removed to make this swap. is this the case? what has to be done to switch the starter?
Thanks!
Doug
Remove / Replace :
1) Disconnect the battery ground cable.
2) Remove the components in the order indicated in the following illustration and table.
[1] - Starter motor solenoid terminal cover
[2] - Starter motor solenoid nuts
[3] - Starter motor solenoid cables
[4] - Starter motor bolts (lower/upper)
[5] - Starter motor
