'02 Limited Memory Seat Function | Ford Explorer Forums
logan.d122
MI
2007 Mercury Mountaineer
My '02 Limited has the memory seat remote entry feature. This is when you press unlock on the remote and seat moves to the driver's position. However, every time I try to program the feature it doe not take. I have gotten it to work twice but then nothing.
I do have the easy exit feature enabled which moves the seat back when the key is removed. Would this have anything to do with the memory seat problem? How do I get the memory seat feature to work properly? HELP!
Thanks.
Have you disabled the easy exit feature to see if the memory feature then worked?
