02 Ranger - No brake warning light in the cluster | Ford Explorer Forums
vagrants
Indianapolis, IN
2002 XL
I don't know much about auto. I searched the web and looked around junk yards (I could only find 1998. It wasn't much of a help) to troubleshoot this no brake warning light. I was unable to get an answer.
When I got this truck, fuse #9 and #13 (brake pedal position switch fuses) had 10A. The manual says #9 suppose to have 7.5A and #13 suppose to have 20A. I made the correction, no brake warning light.
The brake warning light bulb is OK since it shows sign of life at the engine startup. When I engage e-brake, no brake warning light. I checked the switch near the brake pedal. I removed it and cleaned it with an alcohol patch (very dusty). I used AA battery to see if there is something wrong. It appears it's OK if I understood how it works correctly (the voltage on the washer looking thing was 0.02 or something like that compare to 1.45 at the metal that goes into an adapter...it suppose to ground, so it's correct, yes?).
I have not yet checked the master cylinder's sensor. I understand I should check this by pushing down on the float with a screwdriver and see if the brake light goes on (found this in another forum). Is this a correct way of checking the sensor?
How do I check for voltage/resistance at the fuse box (this tells something about the wire, yes?)? I assume #9 and #13 are the one I'm interested in (1998 had a green/red wire going into #13). It appears I get no readings from these fuses with or without having a toothpick on the parking brake switch washer thing (I put (+) and (-) terminals of my meter on the fuse face that shows tiny metal contacts).
I looked for e-brake wiring diagram, I had no luck locating one.
[edit]
I forgot to mention that ABS light is on....not sure if this will make a difference.
Thank you very much
