02 sport trac AC question | Ford Explorer Forums
tincan
Is this operating properly?
When turned on, compressor runs continously.
When is AC position able to vary the air temperature with the temperature
controller .
When in MAX AIR position, the temperature controller has no effect on
the air temperature, just blows very cold air.
compressor never cycles, even when you change the air temp to warmer
using the temp. controller when AC position, even thou air temp does change.
one Ford dealer says this is correct, that Ford added the ability to control
air temp when in Max position in newer models.
another dealer says not operating correctly.
