2003 explorer 80k miles with slight rattle at idle and acceleration while cold but also when warm on occasion. Religiously maintained. Rattle sounds like a solid metal object loose rattling around- not sheet metal rattle, preignition ping, or rod knock. I've read most posts about this and would appreciate some guidance.
I believe the 03 V6 is not prone to timing chain rattle (at idle) or torque converter rattle- which by mosts descriptions, closely matches my symptoms . The noise does not appear to be heat shield related and is very hard to pin point. It's hard to hear in the car but outside, you hear it better with the hood closed. With the hood open, you can hear it, but it's louder under the car. Normal engine noise drowns out most of the rattle from above.
Any ideas on common trouble spots or how to better isolate the rattle?
thanks in advance.
thanks in advance.
