aaron_johnson
- November 13, 2009
- Bloomington, IL
- '03 NBX
I've got an '03 explorer with the automatic 4wd not a awd.
Problem is this.
From a start, when wheels not turned no issue at all.
From a start when wheel turned either left or right a bad vibration shakes the vehicle for about 4 or 5 seconds until you get above about 10-15mph.
Started off not really noticable, now it's worse and when I hooked the trailer up the other day it was much much more noticable.
Any suggestions. I've got the thing up on jack stands now, can't see any cv joint/U-joint issues.
Rear diff fluid changed about a month ago, transmission fluid changed about 10k miles ago (I think they did the transfer case too) and front diff will be done this weekend along with the transfer case (since I'm not sure).
Any suggestions as to what this vibration is from????
Aaron Johnson
'03 Explorer NBX - completely stock
'09 Pontiac G8 GT
'72 Triumph Spitfire SCCA H-Prod Car
'72 Triumph TR6
Problem is this.
Aaron Johnson
'09 Pontiac G8 GT
'72 Triumph TR6
