BUBBAZ572
- September 6, 2018
- CELINA OHIO
- 03 EXPLORER
GOT IN EXPLORER AND IT WONT MOVE.WORKED FINE THE NIGHT BEFOR.I HAVE NO CODES.THE FLUID IS FULL AND NOT BURNT.I HAVE RPM READINGS TO THE INPUT AND INTERMEDIAT SENSORS.THERE IS NO RPMS ON THE OUTPUT SPEED SENSOR.DID A PRESSURE CHECK AND ALL THE PRESSURES ARE ON THE HIDE SIDE.DROPED THE PAN AND VALVE BODY,EVERYTHING LOOKS GOOD.REMOVED THE VALVES AND CLEANED THE VALVE BODY.ALL LOOKS GOOD.PUT BACK TOGETHER AND STILL HAVE SAME PROBLEM.DROPED TRANS AND TORE IT APART.EVERYTHING INSIDE LOOKS GREAT.NO BUTNT OR BROKEN BANDS,THE CLUTCHES LOOK NEW(STILL READ PRINT ON THEM).FOUND NO BROKEN HARD PARTS.CONVERTER LOOKS OK.REFIEF VALVE IN PUMP IS NOT STUCK..PUT BACK TOGETHER WITH NEW RELIEF VALVE AND SHIFT KIT AND NEW CONVERTER. REINSTALLED TRANS AND STILL HAVE SAME PROBLEM. JUST WONT MOVE.
NEED HELP! WHAT DID MISS?
GUYS GIVE ME SOME IDEAS PLEASE
BUBBA
GOT IT FIXED. AFTER A REBUILD,SHIFTKIT AND NEW CONVERTER IT NOW WORKS.
THE ONLY PROBLEM WAS THE RANGE SELECTOR SWITCH.SPENT $1000 AND ONLY NEEDED A $60 SWITCH!
BUBBA
