geneT
- February 16, 2009
- Western NC
- '03 XLT
Hi --
Yep, I'm new ... Google brought me here searching for a single solution for a generally satisfactory vehicle.
We live up a steep, winding driveway.
The Explorer is '03 XLT 4.6L v8 with Control-Trac, "3.73 LS Axle".
At one turn, the driveway fully loads the front-driver's side and rear passsenger's side so that the front-passenger's side wheel is lightly-loaded or even a few inches off the ground.
Under those conditions, the front passenger's-side wheel spins freely and the Explorer stops all forward motion ... apparently all the power goes to the unloaded wheel.
This is also true when I switch to 4wd Hi, and 4wd Lo.
The only solution is to back down and take a run at again - to get past that spot on pure momentum.
Apparently, the center differential is not even minimally limited-slip!
NOT what I expect from 4wd nor this package.
The techs at my dealer (who seems to be ethical and competent) say this is normal!
And my '02 F-150 XLT has no such problem!
SO:
Is my Explorer designed to put all power to that wheel?
Or is there a "fix"?
thanks/gene --
btw - if this has been handled a) "my bad" - I missed it, b) please aim me in the right direction
SO:
thanks/gene --
