"03 speed control and lighting malfunction | Ford Explorer Forums
MusicFan119
Clifton Park, NY
'03 explorer sport trac
I have a problem with the speed control which does not activate when the buttons are pressed.
There is great malfunction with the rear break lights and turn signals. If th e steering column is in the highest setting the turn signals work but the main break lights do not. If slight up word pressure is placed onto the steering wheel everything functions properly. If you drop the steering column to the next lower setting the break lights do not work and the signals make a rapid clicking sound and do not light up. Any suggestions on what the problem may be?
