taffy.c
- October 23, 2007
- Minneapolis
- '03 Limited 4x4 4.6L
Hi there,
The transmission in my 03 4.6L Exp (100K miles) is in bad shape and I need to do something soon. I took it to my Ford dealer and they ran the codes and told me that there was something serious going on - missing 3rd gear completely amongst other things. The next step they told me was to spend about $400 to open up the transmission and continue the diagnosis.
I then went to Kennedy transmissions in Minneapolis. They test-drove and also said there was something serious and that a rebuild was required. They said that they can't give a final price until they drop out the transmission and take a look at the work required, but estimated between $2,200 and $2,800. I felt a lot more confident in the people at this shop than I did at the Ford dealership.
A friend who is a mechanic suggested a 3rd option - purchase a transmission from a bone-yard and pay him $300-$400 to do the replacement. I've looked at car-part.com and a couple of other sites and it looks like I can pick up a transmission with less than 40K miles for $800 - $1,000. That would make the entire job around $1,200 - $1,400.
The risk in the last approach is pretty clear - what if the replacement is a dud? But then even if I had to do it twice I'm still probably no worse off than the re-build price.
Anyway - I'd like your advice on which is the best path to take. I've read so many reports of problems with these transmissions that I'm a bit nervous that a used one with even low miles could have problems. But then I've also read of problems with re-builds too. Or should I get a re-manufactured Ford transmission? What would you do??
Thanks ... TC
Thanks ... TC
