04 3.0 dohc no heat | Ford Explorer Forums
04 3.0 dohc no heat
360cid
Snohomish Washington
2004 Explorer XLT
I have a 04 Taurus that has no heat out of the hvac. Already replaced the blend door actuator, has heat to the heater core, and a/c blows nice and cold. No change in temp no matter where I set the temp control knob on the dash, and what dash position I set the vent selector too, and the fan control works just fine on all speeds. Could it be a fuse? Thanks all!
Has heat to both hoses! Surge tank is also at the proper level! There is also a second door that is controlled via linkage that the actuator controls that is in good working order as well. I checked that when I replaced the actuator!
