04 Explorer 4.0 SOHC question | Ford Explorer Forums
Kbatman777
Wood River, IL
2004 explorer 4x4 4.0 SOH
Hello, I recently bought an 04 explorer,4.0 SOHC
It runs great, idles fine, drives fine, and has no leaks or problems. My question is whenever I put it into drive, it takes a good 3 or 4 seconds to feel the full shift. Reverse doesn't react this way and it never dies, but there is just a very slight pause in between switching to gear and being able to go. Any idea what it might be and what I can do to change it. It isn't a problem now but I would like for it not to create a bigger problem. Thank you
Did you check your trans fluid?
Put in nutral after ex is worm. Check level if this dosnt fix it your trans pump maybe going out.
Welcome to the site
Tony
