04 Explorer Sway Bar? | Ford Explorer Forums
MI
01 Ranger 4x4
I heard a while back there was a TSB or some type of recall on the sway bar mounts for the 02-04? explorers.
My moms explorer (04, 4.6L, Auto 4x4) is squeaking like crazy! I am pretty sure its the sway bar mounts for the front susp.
Does anyone know of any updated mounts?
Thanks
If you're sure that's what it is...
check out ExplorerExpress.com They might have what you need. Suerte!
It looks like they only have a swap bar upgrade for the rear.
I see...
at this point, someone who knows exactly, I'm sure, will tell you how to go about finding one. Suerte!
I had the same problem on my '05, took it to Ford under warranty and they greased the front sway bar bushings and i haven't had a problem since
Ford sway bar bushings SUCK... I had the stealership put a new set in last year.
12 Months later they are crushed.
Interesting...They supposedly greased them on it and the sound came back a few months later. I had heard they made updated mounts, anyone have any info on that subject?
