jackfr
- January 8, 2016
- 2004 explorer
Have a 04 mountaineer with bad timing chain noise in front. Took of front and found primary tensioner broken. all other parts looked good. Installed new tensioner ONLY. Thought I could get away with it. No way. The new tensioner lasted about fifteen second and the rattle started again. Took it back apartand the brand new tensioner blew apart. Took off valve covers for better inspection and both cassettes appear fine with no broken pieces.Thought that the tensioner may have been no good and reinstalled another one.
Same result. tensioner blew apart again.. Question can just the primary chain be replaced? It appears that the primary chain is stretched enough to rtemove it without loosening jack shaft bolt. Question Is the primary chain suppose to be able to remove without removing the jackshaft sprocket.
It seems that the tensioner flexed too far against the chain to cause it to break
did not undo jackshaft bolt but want to change just primary chai ,guide and tebioner do I need the 6488 tool to do this its kind of a deal breaker(230 for tool). any comments are most welcome
