E.B. Cornburner
- April 20, 2007
- Oshkosh, WI
- 2004 Eddie Bauer
Reading the thread on the '02 throttle body mod got me thinking yesterday, so I went out and looked at mine, and yes, there's some little "vanes" in there that I've concluded solve a twofold problem...First and foremost, they're in there to eliminate a "swoosh" or squeal from the throttle body under light throttle openings. Second, they're in there to help create a progressiveness to the throttle bore, so there's less of an abrubpt feeling as the throttle is opened. Well, as us throttle-by-wire owners already know, there's more than enough of a lag in the throttle response than most people like.
My solution is mind-numbingly simple. It can be approached one of two ways. First, let me explain the difference between the '02 throttle body and ours. The '02 had the "vanes" cast right into the throttle body itself. Ours do not. They're moulded into a little 1/4" thick spacer that sits between the TB and the intake plenum. What I did was simply take the TB off, pull off the spacer (which is also your TB gasket, and is for the most part reuseable) and remove the vanes from it with a die grinder. It's just thin plastic, and grinding them goes real quickly. Be careful.
The other approach will be concluded completely as soon as tomorrow. I ordered an aftermarket TB gasket from Carquest, which judging by its price (~$4) probably isn't anything special, just a regular old gasket. In this case, if I'm right, the spacer with the vanes could simply be eliminated altogether. Both ways will accomplish the same thing.
After putting everything back together, my first road test was very impressive. There's virtually no lag time in the throttle response anymore. Touch the throttle, and it's right there. Paired with a K&N drop-in filter, the power at WOT is equally impressive...By the precise calibration of my butt dyno, I'd say the combination is worth about 7-10 HP. On a 55 MPH kickdown, this thing pulls like a freight train now. Much improved over the stock TB spacer/paper air filter combo I was running previously. I can't say for sure which helped more, but since I did the filter first and didn't notice all that much difference, I'd be willing to say the modification to the spacer helped out a bit more.
What's more, is I have a feeling I gained a little MPG out of this as well! I filled 'er up last night with E85, then took off for a road test on a 55 MPH road with the cruise set at 58, and according to my message center, I was getting 18.2 MPG! All that MPG was lost when I headed back home and was driving it like a rental car! Hey...Ya gotta test both power and MPG, right?
Give it a try...I'm confident you won't be disappointed.
