Chargerjay
- November 8, 2020
- Location
- BC
- Nanaimo
- 94 Explor + 05 sport trac
Hey Guys, so, I've tried going thru the forums and find lots of info but each thread is a bit different and none seem to be what I'm looking for. So here's my issue; neither the driver's door lock button, or the passenger door lock button work. The unlock works on both, and the keyfob and key pad both work to lock doors. I have pulled the door panel off a few hundred times, well not really, but more than a few times. Gone through every spec of wire in that door. I made a jumper and could not jump the locks to lock them but could jump to unlock. So ima thinking there's nothing at the switch. Now I've gone through that joyous harness in the door frame and found and fixed 5 broken wires, no change. I've hunted for the relay to no avail, and put a gallon or two of penetrating oil down the latch assembly, the usual things. So what I'm thinking is where ever the passenger's door, and driver's door lock wires connect is a great place to check. Any help or EMTs are muchly appreciated, I've been working on this truck for almost a year and this is the last thing to do.
