05 Ford explorer sohc | Ford Explorer Forums
Awlawn care
Ohio
05 Ford exolorer
Photos of cam settings. Trying to set time fires but dies out
Changed chains can't set can any help
You need the OTC. there is a tool that holds the timing chains at the correct tension. Without it you are always out a few degrees. It also holds the crank at the correct position and the cams at the correct positions. Then you tighten all the bolts. No timing marks. Check out Streetrod2000's posts for a home made version. you need to trash one of your tensionsers to get his to work though.
