05 Sport trac window problems!!! | Ford Explorer Forums
Ephrata Pa
05 Sporttrac XLT
I have a 05 Sport Trac XLT 4.0 - All Stock.
Currently, none of my windows work except the rear window. It was an irregular problem. Conveniently only acted up on days it would rain, a weeks straight of hot and sunny there was no problem what so ever. Frustrating to say the least.
I found that after it would act up if I opened the door to its max then close it they would work.
I had searched the archives and got some pointers but in some cases they didn't apply to my style vehicle.
My question, is it a ground in the door or under the dash? Is it the switch unit in general? Could it be a loose or frayed wire on the instrument cluster?
On an unrelated note my Odometer flashes at me along with my tachometer and speedometer will drop to 0 while driving then bounce back up my speed. ON one instance my headlights had turned completely off while driving when set to the Auto setting. I did just replace the 20A fuse under the hood and spot 19. Will that help at all?
Any pointers or suggestion would be greatly appreciated!!
Thanks in advanced!
Check all the grounds behind the kick panels.
The window issue will probably be a broken wire in the flexible door boot.
