kpkozy
- November 28, 2010
- McKeesport, PA
- 06 XLT
I have a leak somewhere around the parking brake assembly. It leaks when water is poured into the cowl. I unbolted the brake assembly so i could see better, and then poured water into the cowl again. I got a stream of water pouring out of the top right brake assembly bolt hole. So i got some permatex out and put some on bolts and around bolt holes and put brake assembly back in. I still have the same leak, so there must be another point of entry. Is something clogged that there was so much water building up and coming in through the bolt holes???? There is allot of water draining out behind fender like it should. I cant see where the cowl drains to. I'm thinking about taking the fender off next, but the bolts in the door piller are behind the support metal of the fender and look just about impossible to get to from the fender/door gap or from behind door. Do I need to remove inner fender well first, then reach back through to those bolts????
Any help with a possible leak point or removing the fender would be greatly appreciated.
