pjw73nh
- March 20, 2011
- 08 LTD
Greetings,
My 08 Ltd 4.6 radiator has had it. I am pretty sure the car was in an accident of some sort before I got it (with 60k) as there is some misalignment of some front end body parts.
I *think* it is the original rad as it is stamped 10-17-2007 on the mfr date code. That said, the car has 118k miles on it now. I have already replaced the "Y" connector to the rear heat. The car has been losing coolant for about 5 months. At first it was about a cup or so per oil change. Now it has progressed to the point of 2-3 OZ every time I park. More-so when the car is cold and sits for a weekend or so.
There is a crack in the upper tank, but not leaking. Only a matter of time I suppose. The lower tank where the cooling tubes go in is wet. There is coolant being pushed on to the engine when driving. There are white crusties on the radiator. I am pretty sure the rad has had it.
See pics here: https://goo.gl/photos/Aujg6wUs6UD1kdLh6
As a point of interest, I put a new condenser in about 4 years ago. I did NOT have to drain the cooling system or pull the radiator or fan to do it. I was able to finagle it out and in just by moving the rad back toward the fan..
I've done an extensive search here and also viewed FordMakuloco's fantastic videos on ford products on youtube. I still have a couple of questions.
1. Anyone have any recent comments on The Spectra Premium Radiator CU2952? It comes highly recommended by many, though a few have reported negative results. I wrote to the company today and they tell me they are made in China, and that Amazon is in fact, an authorized seller, and to their knowledge there are no knock offs being sold. Amazon has it for $140. RockAuto has the RAD38 OEM for $183 delivered.
2. Can I do this job without pulling the fan? There is a special 36 mm wrench for it, but I don't quite understand which way the nut should turn to remove the fan. In addition to wondering how to hold it from turning when wrenching it.
3. Adding transmission fluid is a royal PITA with this car. (6R60) transmission. It's sealed and has to be done from the bottom. Can I fill the ATF cooler tank after I install the rad and before I connect the lines. How much ATF is lost when replacing the rad?
4. If I can't get the old trans cooler lines off, will the existing fittings thread into the CU2952 ports? There is conflicting information about this referencing a 1.5 and 1.25 pitch thread issue..
Thanks in advance for any further tips, tricks suggestions you may have.
