CPDecker
- November 14, 2010
- Matamoras, PA
- '08 Mountaineer PremierV8
I had a set of 235/65R18 Cooper Discoverer CTS tires installed on my 2008 Mercury Mountaineer Premier V8 AWD with about 40,000 miles. The tires were balanced and the vehicle was aligned. Following the installation the vehicle began vibrating at highway speeds. The vehicle did not vibrate on the way to the tire shop.
I returned to the local tire shop the next day and they did a road force balance on all for tires, each one was off by 1 ounce. This did not resolve the vibration.
I returned to the shop again the next day at which point they told me it was impossible for the vehicle to be vibrating due to the tires. After the mechanics took the vehicle for a drive and then me driving with them in it, they agreed there was a bad vibration coming through the body (floor boards and door handles). They pulled off a rear tire to balance it again and they then claimed that the rim (stock) was bent at which point they tried to balance it again but the vibration got worse.
I did have a vibration when braking that appears to have been caused by a warped rotor. I replaced the rotors and pads today. The vibration during braking is gone but the vibration that is coming through the body, and to a lesser extent through the steering wheel, is still there. The vibration is noticeable at about 35-40 mph and gets worse at highway speeds.
I driving the family to Florida, about a 20 hour trip, in a couple weeks and I need to resolve the problem by then. Is it possible that they could balance the tires twice before finding a bent rim? Are bent rims common? This is my wife’s vehicle and it has never been off-road.
Any ideas? Suggestions? Thank you in advance!
