clamb
- November 10, 2010
- Maidstone, Saskatchewan
- 99 XLT
I am getting poor fuel economy, 10 to 12 mpg on highway trips. I have about 230000 kilometers on the truck but only about 20000 kilometers on this engine (the third). Recently had it in to a local garage, where they reset the fuel trim codes, with no gains to fuel economy. Checked the fuel pressure, fluids, scanned for codes, as I was not showing any on my reader, garage found none either. The only thing my reader displays in EV. Will not pass Evaporative systems test on scanner. The only thing that I am aware of that is an issue is the drivers side valve cover gasket is leaking oil. Was wondering if I could be getting a vacuum leak from this. This engine was recently rebuilt, & tranny rebuilt at the same time. Pulled all spark plugs and they look fine, except for the rear drivers plug is a little darker than the rest. All new plugs, spark plug wires, O-2 sensors. I don't know what else to look into. The original engine seized after driving it out of the Ford shop when they replaced the lower intake manifold gaskets when it started leaking coolant externally. (they never changed oil after changing gaskets). I replaced that engine with a new drop in and after about 80000 kilometers this engine blew a head gasket, filling one piston with coolant and hydrolocking. I fear that the 3rd engine may blow too and am afraid to drive the Exploder anymore or any distances with my family.
Is it possible for a sensor to be defective, but not throw codes on the scanner. What tells the engine to "choke" for cold starting /operation, could the sensors think that it is always cold & not trigger fault codes?
Anyone have any suggestions?
