1354m swap wiring | Ford Explorer Forums
1354m swap wiring
lovebite
Allen Park, MI
'98 sport
Okay, I was planning on doing the swap tonight on my '98 SOHC to get rid of that control trac stuff but ran into some concerns. I have been looking for a couple hours with a little luck. There is a sensor on the back of my 4405 with three wires on the out put side of the case and the brown wire. Do I need to connect these to anything of the 1354m or can I just leave them un connected? If I do leave them unconnected then the hole for the gear driven speed sensor on the case is not used? If this is not used can I simply put the VSS sensor in this opening to seal it up with no problems? I would like to get this wiring stuff firgured out so that I can swap this Tcase in tomorrow on my day off if anyone can give me some advice.
bump. Anyone? I am 1 bolt away from pulling the 4405 Tcase off.
There is a large connector near the chassis (on the driver's side). Thats where you will make the disconnect - which will remove all the transfer case related wiring (including the shift motor). The side effect is that you will get a blinking 4HI/4LO (or whatever it is) lights on the dash.
Put a regular (gear driven) VSS into that hole to plug it up and prevent fluid from squirting out.
okay thanks IZwack. this should be a done thing here shortly and I will be done with that control strac stuff!
what do you guys do when you have the full length console with auto for the 1354m shifter coming thru the floor?
