15-16 MPG? Is something wrong? | Page 2 | Ford Explorer Forums
I switched to 22's, mileage is the same. I don't baby her but I do drive with my eye on the dash. To and from work, I drive at about 65-70, I assume this is the main reason. Going to switch out the air filter tomorrow to see if it help. Thanks for all the input guys, really appreciate it. I'm still considering purchasing a little hatchback focus for my DD, they're not bad looking cars with good mileage.
Unless the air filter is really dirty, I doubt that would help increase mpg. There was a bit of a discussion on that in another thread.
300 miles on the odometer of my 2022 Ford Explorer Platinum 4WD. Can't get above 16 mpg no matter what we do. EPA Rating was supposed to be 18 city 24 HWY. I use Normal Drive Mode & I keep auto start stop feature engaged. Something wrong? Or do I just need to keep putting more miles on it?
Although there are many factors that can determine gas mileage, this is from the Manual;
The first 1,000 mi (1,600 km) of driving is
the break-in period of the vehicle. A more
accurate measurement is obtained after
2,000–3,000 mi (3,200–4,800 km).
Thank you Peter. I'll give you an update at the 2-3k miles mark!
Has your gas mileage improved? I just got a 2022 and I’m almost at 3k miles and getting 14.9 mpg while it is 100% city driving I do get better mileage when on the interstate. I was hoping I would get better than 14.9 for everyday driving. I’ve tried using eco mode and even that didn’t help.
Welcome to the Forum. :wave:
If you are going by the dash display for MPG then you may be surprised to know that the figure is usually overly optimistic. Do a pen and paper calculation to see what you are really getting or sign up at Fuelly - Track and Compare your MPG and get it to do the math for you as well as being able to track all your fill-ups. Several member, including myself use it.
Thanks, I’ll give it a try
I run my tires at 37 - 38 PSI as well, but man does it make for a much harsher ride. I actually wish my Limited had something smaller than the 20" rims. More rubber and less metal please.
If you get desperate, you can always put on 18" wheels. I used the 18" Interceptor wheels for my winter setup on my previous vehicles.
I wish I got that kind of mileage. My explorer is a 3.5 NA AWD and I am lucky if I see over 13 to the gallon city and over 19 to the gallon highway. To be fair, all terrain tires and my cinder block foot don't help much
Yeah, part of me wonders what a V8 would have gotten in this platform. With E85 being $2.96 having the range show as 200 is good enough. I spent most this time here as a lease so my "long trips" was taking family to and from college when it started and ended. That has to be my best MPG ever turnpike w/o any manipulation. If I reset the trip already on the freeway I can squeeze 20.1 untill I hit the off ramp and wait for the light to turn green. part of me wants a Sport but the way I move, its gonna be Hellcat MPG numbers.
That is why I like my XLT with 18 inch rims so much. I mean the 20s on the limited are eye candy, love them, but comfort is first. I use 33 psi instead of the 35, the ride comfort is even better and my mpg don't suffer a bit or at least I haven't noticed any loss. I don't know if the 20s will be fine with 33 but you could try. The 2020+ Explorers "require" 33 psi, that should tell you sometthing.
Yeah, I'm sure the 18" rims are a much smoother ride.
On a side note, we went and test drove a 2021 Explorer ST and it had the oddball 21" rim. I went and looked up 21" tires on tirerack and the pickings were slim. No way I'd go with those rims.
On the highway I get at least 24 mpgs (as much as 27) with my 13 XLT, stock rims, 33 psi. I try to drive at speed limit, not over. If you look at the rpms you shouldn't go past 2k at 6th gear, anything above 2k your mpg will drop exponentially. I also replace spark plugs with OEM ones well before rhe 100k mark, when I bought the truck with 50k miles the sparplugs were toast. I also use 5w-20 full synthetic and I did several drain and refills of the transmission, oem fluid is very important (Moyorcraft LV).
Yeah, I can get between 26 - 27 mpg. In the summer time it's normally slightly less due to running the air conditioning. I normally go right at speed limit up to +5 as well.
I also have been doing the transmission drain and refill. I'm glad it has a dipstick and drain plug.
The spark plugs were fouled at 50k? Yikes, I haven't changed mine out and i'm at ~66k. I was hoping to get at least 75k out of them.
I did install a K&N air filter as well (stock air intake). I'm doubtful it will be noticeable in the fuel economy. But I got tired of throwing out air filters. Now I can just clean and re-oil the K&N as needed.
My lease came with 20 and I kept having to buy tires for them due to road hazards where 1 tire would have more tread than the rest. Luckily this last tire was covered though Tire Rack and not much tread was lost between the other 3 that got replaced. I'm at 40 psi and come back down for winter months. Eventually I plan on going 18's but not just yet.
late night trips I am at speed limit but daytime that's impossible. People hyper-mile, have warrants or just get onto a 60 mph freeway doing 39 and stop at the top of the on ramp. Streets they drive 11 under and run the already red light we could have made if they at least did the speed limit. I'll keep an eye on the RPMs in between passing up rolling road blocks; I try to have the instant MPG screen up but people will see you doing "3000" MPH and cut you off to do 42 no blinker. My mpg would understandably go down winter time because I would remote start all the time. At home the snow will be past the wheel wells so there is no put in in snow and punch it, at work I had to buy a shovel because that same amount of snow will fall and ths snow crew will clear the isles and plow us in. From my locker to where i park is 3000 steps, I'm tired and aching not trying to get into a cold vehicle after fighting snow and ice plus that plowed in situation to get out.
I'm about to do my 2nd drain fill and learned short sleeves is not a great idea reaching in between that radiator hose to get the dip stick top off. I was surprised there was a stick this late in car years, they still have them on the new Explorers? I also learned do not put any tops near that opening where the hood latch and horns are, they will be eaten by the front fascia.
I might pull a plug to see what they look like, 2 cars ago my Cruze would consume plugs yearly due to coil packs frying themselves. 70K miles I had to have gone though 18 plugs with 2 sets being tuned. I was hoping this would be like my old Century where you could pop the mounts, put in neutral and ratchet the engine forward to get the back plugs. I guess I'll look for all the gaskets long before the time comes to do them.
I was always told not to use them because they would coat sensors even if you made the filter faintly pink verses blood red with oil oozing down your arm. Some folks would void warranties for turbo dusting if you had a K&N on. I kinda toyed with the idea once but a few folks said the sensors changed and the 19 would leave a hole you can't fill in the intake. I did accidentally leave the tabs for the air box out and it sounded kinda good. I fixed the tabs back in the next day when I could see where they went in since I changed the filter in the middle of the night. On that no tossing filters route, I've seen they have washable cabin filters too. I usually change mine out 2-3 times a year due to pollen. I also don't have my windows down due to pollen. Between here and NJ when i was stationed there, that yellow coat of pollen would tear me up for those few months. Come winter time I always forget to wear a mask and get severe allergies when I change the filter out.
Also did brakes since the rears were toast and winter traction was crap when the car couldn't control the rears. I had low tread tires, swapped them thinking that was the only issue and found the rears were almost on the backing plate. The wear from what I believe didn't get crazy until I had some kind of hill hold feature put back on. I assumed it was not the hill decent feature but the hold my manual Accord I traded in had that pissed me off. You could feel the car fighting you when you leave the light and when parking in a garage you could hear the rear brakes still holding on audibly.
