1979 Fullsize Bronco Coil Spring Buckets | Ford Explorer Forums
cole01
Dryden
1986 Bronco 2
Started to take out my Dana 30 solid axle to put in my fullsize dana 44 solid axle. The Dane 30 axle was narrowed, so I made the 2inch spacer blocks to space out the buckets just need to know where to mount the buckets verticaly, .Any one with measurements would be great. sorry for the spelling:D ordered wild horse 5.5 rock crawler coils if that helps:salute:
If you set your current buckets at the height that your stock buckets were at, those 5.5" coils should net you 6-7" of lift. That's on an Explorer, but I don't think there would be much difference in weight between the front ends of an Ex and a BII. I believe those coils compress just shy of 17" so hopefully that gives you some baseline measurements.
Maybe Froader or Stic-o will chime in, these guys run those same coils.
