- February 18, 2015
- Phoenix Az
- 1991 aerostar
Either remove the 4 nuts from the firewall and remove it as an assembly or as you said, remove the rod and the pedals come out. As an assembly is better as it keeps all the washers with the unitYou in luck. These should have a little trading value. How do I remove them? Are they kind of bolted in like Fox body Mustang pedals or are they more like 1960s-70s with a fat through rod welded to the clutch pedal and slides through the brake pedal? I'm sure that it's not difficult. The worst part is laying up in there to get to them. Clutch pedal is down and stuck.
