1987 A4LD low/reverse servo seal replacement. | Ford Explorer Forums
jrriggs
taylorville il
1987 ranger
how do i replace reverse servo seals? hey i'm new at the sight. so please whoever replied to my question if you could reply again.when i signed up i messed up on my email imformation.
Welcome to this forum! I've renamed your thread, and moved it into the transmissions section. Remove the pan, pan gasket, square block off plate with 4 bolts, and the servo gasket. Grab a tab on the servo with a plier, and pull out the servo. The TransTec Viton D ring kit is recommended instead of using plain O rings. Don't lose the large spring.
