1991 HELP child locks back door | Ford Explorer Forums
ras
michigan
1991 Edie Bauer
Is anyone else having trouble with the locks on the back doors. I just bought a 91 and the child locks wont disengage in the back. Anyone have any suggestions??? Also my front seats wont adjust with the buttons on the side...fuse maybe????
Couldn't hurt to check the fuses. Also check the plug and make sure it's connected. As for the child lock, it's just a manual switch on the side of the door you need to push down. If you've tried this maybe pull the door apart and look inside.
I had problems with mine when i first bought it....i ended up havin to use a wrench to switch the locks back to normal....try some wd-40 and give it a shot...
those are just to adjust the air bags in the seat. It will buzz in one position and quiet in the other. Lumbar support.
Squirt lots of oil in
and keep working everything. I had rear latch problems because the previous owner, like everyone else, never lubed the latches. I used a pump can and things started working after a while. Think of the extra oil as door rust proofing.
Wow great advise Iwill try them all and let you know....thanks alot everyone
