1991 Manual Hubs acting up. I think? | Ford Explorer Forums
Big E
Albion MI
91 XLT
Hello. I just got done putting in all new carrier, pinion, and stub axle bearing in the Dana in my Explorer. (Also a Detroit Ez Locker, but that don't matter) The reson I replaced all this is because when I put the truck in 4x4 lock the hubs in the wheel went all over. I had a VERY hard time holding it straight. Now that I reaplced all those bearings, the truck wants to pull hard right. I have checked the u-joint on both sides and even the inner one. All good. I am wondering is maybe I have a manual hub that is hanging up or messeg up. Some help would be great and help save me alot of time now.
Eric
I am curious what a manual hubs acts like when it is bad. When I had my auto hubs I could tell reallt easy. One more thing I was thinking about. Anyone see the bearing inside the spindle go bad. I am wondering if the axle is rubbing causing it to grab on one side then the other side. Not sure if this helps. I see nobidy has replied yet. So that probably means you guys don't like me (crying over here) or I have a problem that nobody else knows how to fix. I hope it is number 2! :D
Eric
